I've been enjoying my new progress for about 3 weeks now and haven't had it much above 550 stove top. This morning about 7:30 I went through my normal routine - filled it half way on the morning coals with several four to six inch splits of doug fir (15-17% mc) and a bear brick, let the fire get going and engaged the cat at about 275, then shut the air down completely.
Stove was unusually dark at first (no flames). After a couple of hours the stove top temp was up to 575 (which is a bit unusual as it typically levels off and cruises around 450-475). I then hear a slight "whoof" in the fire box, stove top is approaching 600 and appears to be rising quickly. I fiddled with the air lever to make sure it was all the way down, heard a tiny click as I put downward pressure on the lever and then heard another larger "whoof". Secondaries fired off pretty heavily for about 20 minutes then died down. Was getting a bit nervous as the temp kept rising and finally peaked at just over 625. Temp is now down to about 500 and the stove is cruising normally.
I don't know what was different about this morning. Same wood, same weather, same routine. Perhaps a rogue split or two got in the mix? Maybe more air was getting into the box because something was hung up with the air control?
