Problems with USSC 5660
Srnewman1
1
Frazier Park, CA
Having problem with either the side board or wiring harness in that auger will stop running unless tension is put on auger wire at the board connection. Tried to order a new harness but they no longer carry them. Any thoughts? Tried to talk to a tech at USSC but no luck either.
I haven't looked at the way mine connects, but it sounds like maybe the connector at the board is loose/worn. Can you just replace that?
Just my initial thought
Sounds like either a bad wiring connection, or a crack in the circuit board solder. Probably the same board as mine, IIRC it should be fairly large paths and easy to touch up.
Reactions: Mt Bob
