Hello,
I am new to the group and to heating with wood. I had a Fireplace XTR Elite insert installed into an existing masonry chimney early in November. The install included a new stainless steel liner which was insulated. Initially the stove burned OK using 3yr old elm I had on hand. It never seemed to develop a raging fire however and I would burn it wide open most of the time just to keep the flames. Recently, however the fires have appeared even more "choked". At first opening the doors a hair for a few minutes would seem to alleviate the problem but I have now stopped using the stove. I looked at the top of the chimney and there is definitely tar like creosote up there. I plan to take a better look today. I also have a ton of questions.
What else should I look for? I am guessing the stove has been choked from the start and I already have a decrease in draft due to creosote buildup? The air damper control is on the bottom of the stove, is it common for this to get clogged somehow or is inadequate draft more likely? Is there a way to measure the temperatures in this flush mount insert? I can think of more but I don't want to seem too needy in my first post
I would like to have a little more knowledge before I call the dealer.
Thanks in advance
![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
Thanks in advance
