Help,
My Napoleon NPS40 is not working properly. It worked fine for a couple of months then I had major problems. At first I thought it was the pellet quality but I tried several different pellets and they all are the same. My pellet stove lights the pellets OK but the fire only burn by the the ignition plug. The fire will burn poorly for a little while (bad combustion:lazy flame, orange black color) then go out. Sometime the stove shuts off and I restart. The flame goes out and when hot enough starts up again and actually shoots sparks out of the fresh air intake. The stove is direct vented horizontally with 4" venting. I live in a drafty house so I have no fresh air intake. I ruled out the pellets and installation because it operated correctly for a couple of months. I then checked for air leaks around the door and ash door with a piece of paper as shown in the manual. After checking this I proceeded to take the whole unit apart. I cleaned the exhaust motor, venting pipes, and exhaust manifolds in the stove. I then cleaned the fresh air intake pipe and manifold with my shop vac. After putting it all back together it still is not any better. Sadly I bought the stove on the internet from a company called Zoobler who is across the county. They have tried to help me over the phone but cannot find a solution. Napoleon has not responeded to my E-mail for help. The Exhaust motor runs but seems to be blowing out weak. I would appreciate any suggestions.
Thanks Jason
Thanks Jason
