Bought a Bio Mass 80 gasification boiler. I have hooked it up as an open system to an 800 gallon stainless steel insulated tank. I've hooked the cold water from the bottom of the stainless steel tank to the cold inlet of the boiler and the hot water from the top of the boiler drops into the tank. I have a third line as a mixing line running through a Danfos mixing valve with a valve on it to restrict flow on the bypass. I am trying to heat this tank up without drawing any water out to the house or shop and I am not having any success getting this tank up to temperature. Any suggestions???
This boiler has a BTU output of 275,000, so with my calculations it should heat this 800 gallon 30 degrees of temperature rise per hour. Are my calculations correct?
