I rebuilt a VC Defiant Encore, fired it up, and...
Its been a little underwhelming. I’ve been running this stove almost non-stop for a week and it just doesn’t seem to put out the heat that it should. Its been running all day and the temp in that room is around 65 degrees.
Here is my scenario: It’s the model #0028, almost a complete rebuild (had everything apart except for the top and exterior sides). I had to add an 8" oval to 6" round to mate it up with my 6" insulated SS flex liner (exterior chimney against west wall of house). I don’t believe draft is a problem. I’ve been running the stove around 650 griddle top temp. I have to watch it because its gone up to 750 a few times. With the cat engaged, the stove stays hot, but the stack temp goes down to about 300. Also, while the griddle may be 650, the sides of the stove are closer to about 400. Are these temp differences normal?
The stove is on the first floor, total area about 700 to 800 sq ft. This first floor is two big rooms-kitchen & living room, and the hallway leading upstairs. The stove is in the living room which is about 350 sq ft. The total house is about 1600 sq ft. Now, this IS a drafty old farm house, circa 1864. “Balloon” style framing. Insulation was blown in about 15 years ago. Its not that bad though, and I’ve sealed up a lot of drafts. I’m not expecting to have that room roasting, and I know its way more efficient than the big steel box stove I was using. However, while I was using more wood in the steel box, it seemed to radiate the heat better.
Here are my ideas:
-Should I invest in something like an eco-fan to try and distribute the heat? The ceiling is 9' high.
I have friends in a similar drafty old farmhouse with a VC Vigilant and they really like their eco-fan.
-Should I think about swapping it for a bigger, perhaps more radiant stove next year, like a Jotul?
-Could the reduction to 6" be causing a problem? I didn’t think so because it seems to have plenty of draft.. No problem getting the stove up to temp. I even brushed the liner before installing.
-Should I keep quiet, have another beer, and think about all of the wood I’m saving?? ;-)
btw, I’m still burning the wood I put up in the fall of 2005, so its fairly seasoned.
Thanks for any suggestions/input.
Here are my ideas:
