Problem: Auger not turning, Jamestown JT2001T serial # WH12634 purchased October 1991. (fireplace-insert style)
Event: Fire was burning well but suddenly went out. No pellets in firepot.
History: Combustion motor and C880 electronic control board are 10 years old. Otherwise, all components are original as far as I know, including auger motor. (I’m second owner - have owned it about 25 years.)
Troubleshooting:
Bud Heberling
Harrington, Delaware
Troubleshooting:
- Removed pellets from hopper, no obvious auger jam observed.
- Cannot turn auger by hand (could be broken motor gears I guess?)
- Auger motor does not appear to be running but not 100% certain
- Turned stove on, hit start switch, green light on, turned timer but auger does not turn.
- C880 board has one fuse – fuse is good.
- No high limit reset switch found – two yellow wires lead to what appears to be a temperature sensor at the front (near the blower speed control).
- Vacuum switch rubber hose looks good and both ends are connected.
- Auger cutoff switch is not in contact with plunger that appears would shut off auger motor in case of a jam.
- Auger motor label a bit tough to read, look like: “EGM 5817 120 V 7/93 60HZ 1RPM ,55AMP MOD734 Impedance Protected”
- Before I purchase a new auger motor, I’d like to troubleshoot by bypassing some of the safety devices (high temperature switch, vacuum pressure switch, auger motor jam cut-off switch) to see if the auger motor will run. Do I simply unplug the wires from each safety device (one at a time) and use a jumper wire to connect the two wires, thereby bypassing the device? I would plan to test each device separately, one at a time.
- Also, anyone know the gasket size to use for the base the firepot sits on? Mine’s pretty worn.
Bud Heberling
