I have 9.5' ceilings and am going to build an hearth of about 16" high in a corner of our "great room" (almost 1000 sq. ft.) House is wood frame/pier and beam construction. After reading some on this site, I am thinking I might be wise to use cinder blocks for support and use the appropriate cement board(s) on top of this upon which well will lay stone or tile. That way no combustibles are near the bottom of my stove. Also, the instructions call for 36" clearance for sides and back of stove, but in a corner application, would you measure from the corner of the stove closest to the wall? If so, that puts my stove way out into my room. The wife wants rock (veneer) on the walls and I suppose I am going to need fir out for the ventilation as discussed on here. What would that bring my clearance down to if I did that and should I use the metal framing studs to build this wall and attach the CBU to it?
Thanks in advance for your help - I hate being a "newbie". Perhaps I'll be able to pass along some advice one of these days.
Regards from Texas.
Regards from Texas.
