I am going to add 2-500 gallon LP tanks stacked horizontally to my EKO 40 system this fall.
I ran last year with no storage with a primary/secondary system with the boiler tied on to it.
1. If I use the storage for a hydraulic seperator should I use the storage as part of the primary loop or should I just manifold off the top and bottom of the two tanks and eliminate the primary loop?pump?
2. Is this rough diagram piped correctly for water flows or should I tee the boiler and load togeather external of the tanks.
Any advice would be greatly appreciated.
