Recently purchased a 1970-built cabin in the woods with a pre-fab fireplace, make unknown until I visit the cabin in a few weeks. Old photos show the chimney is brick and later faced outside with native stone. Inside has an elevated stone hearth and native stone face with passive vent below the mantle; above it is a pine paneled wall. There are two louvered vents at floor level on each end of the heath. The terracotta flue is maybe 6x6 or 8x8 inches and in good condition as determined by a certified sweep that also replaced the frozen damper with a top damper. A small area on the metal liner at the inside back of the fire box is deformed. I've learned that this style of unit is well past its useful life and where wood framing was used, they are unsafe for other heating options. The 900 ft2 cabin is on a skirted crawl-space and insulated. There is also a small non-vented propane wall mounted heater. I'd like to use the fireplace/chimney for heating. To do so, does the pre-fab need to be removed or can it be modified to fit either an insert or a free standing stove? Is relining required/recommended? Is there anything I am missing or haven't considered?
Thanks
Thanks
