- Jan 13, 2013
- 29
Is there any way of stopping smoke from entering the house during a power outage?
Can the pellet stove run off a portable battery generator?
Frankly, I think everyone should pull the plug at least once to see what happens in the event of a power outage... if you don't have a tall chimney, you're likely to get smoke in the house no matter how well you think everything is sealed up... These stoves are air tight "enough" but not perfect... This is why i have a no power alarm and a battery backup... Little CYA goes a long way.
Ended up doing this about a month ago. Needed to change a breaker in my box and completely forgot I was pulling the circuit the stove was on. Anyway, no smoke in the house. It was a good to know and gave me some comfort. I have a 14 foot liner in my chimney, which helps with the draft.Frankly, I think everyone should pull the plug at least once to see what happens in the event of a power outage... if you don't have a tall chimney, you're likely to get smoke in the house no matter how well you think everything is sealed up... These stoves are air tight "enough" but not perfect... This is why i have a no power alarm and a battery backup... Little CYA goes a long way.
So, for example, if the exhaust goes up a liner in a chimney, things would be good?
Most manufacturers recommend a 3 foot or larger rise to help with a natural draft. If you have a chimney liner, that is about as good as you will get when taking advantage of the natural draft. Honestly, as mentioned, just try it. So you know what to expect.So, for example, if the exhaust goes up a liner in a chimney, things would be good?
I too have a cyberpower ups and a time delay relay that opens the thermostat circuit unti normal power has been restored for 10 minutes. The stove goes into a normal shut down(like the thermostat was satisfied) and stays off for at least 10 minutes and goes back to normal operation once normal power is restored. Mine is a direct vent with no rise. Works good with no smoke in the house.
How did you get the 10 minute delay?
I have and found my basement install is unique. Both the vent and OAK become exhaust as they are higher than the stove. As they start to natural draft the air wash flappers open to let air into the stove. Luckily No smoke for me. I's still like to get a UPS(battery backup) and relay(hooked to the stat circuit) to run the stove out. I don't get any smoke, But there is an oder I can live with, But prefer it was a non issue and controlled itself.
The relay would break the stat circuit and put the stove in low fire mode. The UPS would need to be stout enough to run the stove on low for half an hour(controller has a time hold to keep teh unit on low JIC it calls for heat again). The relay would keep the stove isolated from the stat JIC it did drop and call for heat again while power is still out. Once power is restored the stove would again be able to start as the relay would close the stat circuit again. Although the stove control defaults to low after an outage at least it would start and hopefully keep the house warm. I'd need to set teh controllers heat range once I got home or woke up.
I had fun thinking of ways around it, Now I just need the funds and motivation to get it done!
