Alright so we had an extended power outage on Friday. 9:30 am until 3:00 afternoon.
As in my signature,
I have a Quadrafire CB1200 and a Timber Ridge 55TRPAH
I just have a little simple WEN 56352 / 3500 Watt generator.
I have the stoves hooked up to an APC UPS Smart Backup Unit
I use the UPS to buy time to get the generator out and hooked up if needed. I have had it over two years and this is the first time I needed the gene as power outages occur often but usually less than 1/2 hour at a time.
The APC UPS would not recharge the batteries off the generator which really did not surprise me.
However the Quadrafire CB1200 ran just fine from the generator no problems at all.
But here is my question and reason for posting this....
The 55TRPAH flame went out which I did not realize right away. I came back in saw it figured it was from switching to the generator and turned it back on. It fed fine, lit and then switched to the run cycle and stopped feeding. It almost seemed like the auger motor could not feed pellets from the run mode - but was fine in start up mode.
This does not make a lot of sense to me but I felt it certainly wasn't happy with the gene so I shut it down and just let the quad take over fully to avoid ruining anything in the stove.
Any ideas or thoughts on why this happened and what I could do to fix it? (Besides replacing the stove with another quad or buying a better generator!)
As in my signature,
I just thought it was the ESW way....
