Possibly the dumbest ? ever posted
AtTheBeach
8
Vermont
Can you hear fire burning sounds with a new energy efficient wood-burning stove? I assume no since the door is sealed shut and the ambience is visual, not audial?
Yes you can hear it a bit
With any stove, old school or new, the door is going to block a lot of the snap, crackle and pop of the wood. It will still be there but muted.
I think some stoves come with a "screen door" accessory. Probably not great for efficiency, but could be deployed at times when peak fire ambiance is required...
Reactions: Zack R
The ting ting ting of the stove heating up will be mostly what you hear, then it will be mostly silent.
You can ear it a little bit but it will not be like an open fire in a fireplace. If your stove has a blower, you’ll just hear the blower.
See . . . it really wasn't a dumb question!
If you want a little more snap, crackle and pop you can always toss in some wells seasoned softwood. I find eastern white cedar gives a nice sound show.
Reactions: Dmitry
My dumb question list is the recurring ones that could easily be searched for...
"WHEN IS THE GUMMINT COMING TO TAKE MAH STOVE" is a perennial favorite, along with "what wood stove should I buy, it needs to look pretty and heat a regular sized house".
I'm personally adding any post with the word "ambiance" in it to my list. I don't know why, but once they type that word, you just know it's time to eject from the thread. ;)
Mine is: "I live in a small house on a small lot, I have no room for wood storage and I want to install the stove as a corner install." Drives me crazy.
Actually a good question. I also like to hear a crackling open fire but the epa wood stove secondary flames put on quite a show and more than make up for the muted sounds.
While I did not get a woodstove for the ambiance ;) . . . I do admit I do like the view of the fire and listening to the subdued sounds of crackling and the dull roar of the draft so maybe I do like it for its ambiance.
Sorry Jetsam . . . just had to do it.
Reactions: bholler
I normally burn hardwoods but a pine split snuck into my pile and this morning it was my starter split that I further split to kindling. It was popping quite a bit. I usually crack the door a bit until the fire gets roaring so mostly what I hear is a deep rumble of the roaring fire growing, until I latch the door closed.
Pro tip:
Find some dry cherry infested with carpenter ants. Did this last year on accident. Opening the stove got dangerous.
I can hear the air rushing through my Jotul Oslo if the room is very quiet. A nice sound, I like it.
