I have a Heat N Glo Townsend 1 gas stove, acquired through purchasing a new home. Don't know the age of the unit. I've been trying to get it working for a few days now. Here is what I have tested so far:
1) Confirmed wiring per the user manual
2) Successful light of the pilot, stays on when releasing pilot valve
3) Rearranged logs per user manual
4) Cleared out old ember material, as well as all other debris in the unit
5) Checked main burner for any blockages, couldn't find any.
6) Disconnected the thermostat
When I turn on the burner, nothing happens. I have tested the voltage across the thermopile leads and found the following:
With burner OFF, and pilot lit, ~550mV
With burner ON, and pilot lit, 0mV
Is this a bad thermopile? Or is it a deeper wiring issue? I'm guessing that the burner won't ignite because the thermopile voltage is dropping below the required threshold to activate the main valve, but I'm not sure why it only seems to happen after I flip the switch. I have a new thermopile on order, but figured I'd pose the question while waiting on shipping to see if something else might be needed.
Thank you![shock !!! !!!](/talk/styles/default/xenforo/smileys/shock.gif)
Thank you
