pop-spark heat tech gm26
adrnmrnda
1
I was cleaning and lubing the blower moter, disconnected the two wires to the motor (both black). when i went to reinstall there was a single wire hangig out by itself, i put it where i thought it would go and turned the stove on, when i pressed the auger button the green light came on but the combustion motor did not. I inserted the wire in what seemed to be the only other place it could go and everything started up fine. I pressed the manual feel button and there was a loub pop followed by a spark behind the rocker button and now the stove is completeley without power. What i need first is a schematic to ensure i have everything wired correctly, some wires are in place using wire nuts, and second what does this sound like?
