I've used a catalytic wood stove for well over 20 years, an Energy King Bay 2000c fireplace insert that can be converted to a free standing stove. (I've used it both ways.)
Regarding the draft problem:
In my new house, when I open the stove door, smoke almost always comes out into the room. I know there are a few factors contributing to the poor draft problem which I'll detail as follows.
- I have an Englander NC30 which is an awesome stove, but it's more stove than I need in our new place. (To some degree this was intentional. Given our location at 2000 ft, sub-zero tempuratures are a real possibility.) With the exception of truly cold days (like today) I can't burn it really hot. (Also, much as I've done with the Energy King, I like to load it up and shut down the draft so it will "simmer" all night.)
- I have an 8x12 clay flue lined chimney. I built it, with the help of my brother-in-law, who talked me into what I thought was an overly large liner. (I was thinking 6" would be enough for a wood stove, but it is what it is.)
- The chimney itself is not short but, the actual working distance between the thimble to the top is a bit over 7'. I'm in a Rancher with the thimble fairly close to the ceiling. (See the photo). The chimney height is easily 2' higher than anything within 10' and a bit above the peak of the roof.
- I have a fairly long horizontal pipe run. In the photo below, 3' 2" are visible and there's at least 12" more for the thimble.
I've learned a few work-arounds such as:
- Open the draft, wide open, 10 to 15 minutes before loading wood. (Clears the smoke, heats the chimney.)
- Allow wood to burn to coals before opening the door. (Little to no wood gas or smoke.)
- Be prepared, do it quickly.
___________________________________________________________
To improve the draft:
I was thinking about coming out of the stove and at 8 to 12", use a 45 degree for a diagonal run, and about 8 to 12" from the wall, using another 45 degree to go horizontal into the thimble. That should accelerate the smoke path and reduce the horizontal run to about 2'.
I'd rather not extend the chimney, if at all possible. (Having to climb up a ladder to clean it would not be ideal.) And again, for the sake of cleaning simplicity, I'd rather not line it with flexible stainless.
I'd like to get forum users' opinions on the following, so called, "vacuum caps". There's a breeze here that's fairly constant so, if these things work, I'm willing to give a model that's known to work well a try.
https://www.amazon.com/gp/product/B009KUTR5K/?tag=hearthamazon-20
https://www.amazon.com/gp/product/B00O3IO2CC/?tag=hearthamazon-20
Any comments / thoughts will be appreciated.
Thanks
![Poor Draft Poor Draft](https://www.hearth.com/talk/data/attachments/238/238833-880dbaf641a07faf3524f87059e5128c.jpg)
Thanks
