I have been heating my home primarily with wood for 13 years. I installed a Clayton 1600 indoor
Wood furnace in 2001, and have been pleased with its ability to heat my whole home. But it is too
much heat for shoulder season, and uses a lot of wood (24-30 splits per day). Also, even with burning
It hot and using well-seasoned wood, it has always generated some creosote.
Last fall I installed our Jotul Oslo F500, on the main floor of our 1900 square foot ranch home (the wood furnace is in the basement). Like many of you, we had a brutal winter here in Ohio, so I still used the wood furnace a lot. But if the daytime temperatures were above freezing, and on many days when the highs were only in the 20s, I used my Jotul - it uses half as much wood as my wood furnace. And on many of the -15 below nights I burned both of my wood units so I wouldn't have to get up in the middle of the night to put more wood on the wood furnace. The Jotul does a great job. Yesterday, I finished cleaning the pipe for my Jotul (including moving the stove out to clean the rear exit flue). And I was THOROUGHLY PLEASED with the small amount of creosote I found. Only about a small cereal bowl of creosote was at the bottom of my pipe when I was finished. One note - I burned it as recommended.....get the stove up to 450-550 degrees, then start closing it down gradually. I always had good secondary burns.
Very pleased, and the Jotul is burning this morning!
