Hello! I have a 1,300 sq.ft. stick built cottage style home. The home has a huge basement that was hand dug after the home was built. The entrance to the basement is outside with the stairs enclosed in "room" and then when you get to the first level of the basement. Then the basement has two smaller sets of stairs that descend further and the ceiling is open with exposed rafters and the upstairs floors are accessible from the basement. The ceiling is approximately 10-12 ft tall. There is a chimney made from brick and then cinder block was used as the basement was being created. It appears as if people before me has a wood stove upstairs before with the stove pipe entering the chimney which is now behind a wall in my living room.
I used to have an oil furnace but some children used a water hose and poured water into the oil tank that is buried and then it ruined my furnace. (the kiddos didn't know what they had done and neither did i until it was too late). I then bought a wood stove and had it taken down to the basement with a "hood " that hung above the stove with a fan that I thought could be used to push the air as it rose into the existing ductwork from the old gas furnace. I burned out two fans due to the air being too hot and the stove pipe was a metal that was not appropriate for a wood stove as it was not the proper material and it got exceedingly hot. ( I know all this sounds so dangerous and it was.)
I received a large HVAC system and paid to have it installed with ductwork added and some extra floor vents placed. I would also burn a fire which heats the floor as it rises and radiates heat from the wall that encases the chimney. This is not as efficient as I would like. I just has a new liner installed in my chimney as there was some serious danger due to hardened Creosote from there not having a chimney cap. So, when I had the chimney swept by professionals they were able to really remove chunks of this material and discovered a hole where fire was able to escape and burn within the wall. Obviously, this scared me to pieces and I haven't burned a fire since last winter. Now it's all cleaned out and lined and I'm buying my chimney cap and new stove pipe.
This is what i want to do now and why I need your expertise! I want to safely capture the heat from the wood stove and blow it upstairs so that it heats my home with optimal results and safety. I have been reading and discovered what I already assumed which is that it is not recommended to blow wood heat into ductwork that is designed for an HVAC system. I still have the hood that was made to hang above the stove and wondered if I can buy an inline fan made for wood stoves, wood stove ductwork, and then cut vents in the floor in a few rooms upstairs. I just don't know what I need, how to go about it. what I need to buy, and how to keep it in my budget. I am having to buy wood stove pipe to go from the stove to the chimney but then do I need a different type of pipe to capture the rising heat to be blown into the specialized wood stove ductwork and what kind of fan do I need and how do I attach the ductwork to the vents and what kind of vents do I need? Do I need to insulate in some special way? Do I need specialized material to secure the pipe, duct work, fan? I am overwhelmed. I don't have anyone to help me with this like a man or woman with this kind of knowledge. I don't have any family to help me. And I just don't want to put myself in danger again with my stove.
Please help ASAP as it is cold here in the mountains of NC and I am ready to enjoy my awesome wood stove again. Thank you all in advance! I'm excited to hear your wisdom and guidance!!
With Warmest Regards and Gratitude~ Bobbi Jo from North Carolina Mountains!
