Hi everyone. I've posted a couple of threads previously regarding the horribly stinky flue in our house. See previous here and here. After reading all the advice, plus finally finding a company here I think I can trust, we have a game plan. I'm hoping the experts here can review what we're going to do and give feedback and constructive criticism, point out anything we're forgetting, etc.
First, I'll describe what we're planning. I'll post a brief recap of everything that's happened below that, but the short version is that folks on the past threads agreed that we have a dirty flue, moisture in the flue, and negative pressure inside.
So, here's the planned work:
When they came out, they confirmed we had stage 3 creosote despite protestations of other sweeps (which conforms with what people on this site were telling us), they confirmed that our chimney is NOT too short (a couple other companies had said it is), and they confirmed our flashing is fine. Oh, and they took pics of the secondary flue. It looks like it was literally never used. So, they don't want to do anything with it.
We also talked about a special "wind proof" flue cap, but they said with our chimney being high enough, and far enough away from other tall items, that there shouldn't be such extreme down pressures that it would justify adding the cost. They said the closed system itself should be enough to deal with any wind that might happen to enter the chimney. I still wonder if it isn't worth it to just add it anyway, but I guess we could always throw it on later if necessary.
Some other facts about the house:
ranch style with a walkout basement, located at the top of a hill in southern Missouri (very hot and humid right now, winters can be mild or very cold and very wet or very dry), backs up to a forest. House faces north west, chimney is on the back, fireplace is in living room on main level.
The fireplace has a metal lining inside it. The team says they'll have to saw off "most of the top and back" of the metal lining, but they said that was normal. The fireplace did have built in blower with vents above and to the side of the fireplace. They say they're going to fill those cavities with insulation and "black out" the spaces between the bricks that acted as vents. They're also going to use the line that powered the original blower motors to feed a junction box that they then use to power the new blower motor.
Now a summary of the history, for context.
Honestly, I'd recommend at least reading my initial post on both threads. Here are the basics, though. A year ago we bought a house, had the fireplace flue inspected, fixed a crack in the mortar chimney chase cover, removed a retro-fitted gas insert from the originally woodburning fireplace, and sprayed "professional" water repellent onto the bricks outside. After a season of burning wood that was supposedly seasoned, but soaking wet due to being stored outside during a winter that never stopped raining, we immediately had our flue cleaned when burning stopped in January. We were concerned the flue still wasn't very clean, but the owner came out and swore it was fine. We started having occasional smell issues, so we plugged the bottom of the flue with a homemade "balloon" (insulation inside trash bags) and sealed the top with aluminum foil (dumb, I know). In February, we had weatherization work done on the house, such as caulking around doors and windows, more insulation in attic, etc. They also installed an exhaust fan that they claimed was required by law when weatherization work is done to "prevent bad air build up inside the house." It's always on, and they have subsequently claimed it's such low pressure that it couldn't possible be affecting the smell (and we already had some odor issues before it was installed, plus the big issues didn't start until long after it was installed, and we don't see any difference when turning it off or on). We also have a radon exhaust under the foundation, but again, that was running long before the problems started, and we see no difference when turning it on or off.
Anyway, in April, when the weather really turned to full time hot and humid, the house was flooded with thick, nasty, humid stink. We immediately had several sweeps out, and they all gave conflicting advice. Based on the few points where they did agree, plus advice from this website, we surmised that we had humid air getting in, despite covering the flue with foil, and it compounded to the point that it was so thick and heavy it was pushing past the balloon at the bottom. We tried numerous things, and no combination of windows open/closed, appliances on/off, etc. made a difference. The only thing that helps is burning candles in the fireplace, and we often have to have many, many very large candles burning, depending on the heat and humidity of the outside weather.
Okay, I think that covers everything. It probably covers too much. Please tell me what else I can share that is helpful, and please tell me if there's anything else we should do to make sure we have the best possible chance of beating this thing.
I'm adding the pics from the last thread. I have some newer pics of the inside of the flues, but I don't have them on this PC yet. Working on it!
- Clean the flue
- The new crew we're working with, which seems much more professional than the past 4, agreed with hearth.com comments that we have "stage 3" creosote.
- Before anything else, they're going to clean it with chains to ensure a squeaky clean install.
- Install a 6" stainless steel liner (insulated)
- Blocking plates at the top of the chimney and at the bottom
- Install a CI2600 fireplace insert
- I've read almost the full CI2600 thread, still working through the last few pages.
- This insert is picked because, among those offered by the company we're going with, it has the look we want for the lowest price, plus it seems like it's pretty well liked now that the kinks are worked out.
- Options we're choosing include:
- Cat monitor/thermometer
- Fresh air intake (they recommended this due to the weatherization work we've had done)
- Blower
- Cleaning out and bricking over the ash dump
- Bricking up the existing fresh air intake
- Installing a junction box inside the fireplace so the plug for the CI2600 blower doesn't hang out the front of the fireplace
- Install new stainless steel chimney chase cover
- The quote for all of this is approximately $6,800 all in (cost of just the insert is about $2,700, the rest is materials for the liner and chase cover, labor, other materials, etc.), so also appreciate any feedback on that.
