I picked up the following on a plate hx with these published specs:
3.62 Square feet of surface area
392F High temp / - 320F Low temp
Weight; 4.21 lbs
Size; 3" x 7.5" x 4" - 30 plate
Ports; 3/4" Male NPT
5 gpm each side
90,000 BTUs per Hour..........................215,000 BTUs per Hour
Side 1 Temps.......Side 2 Temps............Side 1 Temps..........Side 2 Temps
In /130.....................In / 70...........................In / 160.................In / 50
Out / 93...................Out / 115.......................Out / 67................Out / 140
My comments:
1) I would opt for a nominal 5 x 12 x 30 plate or more with 1" ports as minimum for a gasification boiler system.
2) BTU calculation: gpm x 8.35 x 60 x delta T
3) Above calcs (side 1 - side 2) seem to be based on a cooling application. I assume heating would be similar. Using the 90,000 calc, based on delta T, btu's side 1 = 92685; side 2 = 112725; 82% efficiency. Using the 215000 calc, based on delta T, btu's side 1 = 225450; side 2 = 232965; 96% efficiency.
3) I don't think the typical boiler application (5 gpm each side) would approach these btu's/hr. Note in the specs above that the closer delta T (90000 btu) is less efficient that the wider delta T (215000 btu). A typical boiler application might be, and I think these are optimistic with this smaller hx (these specs would come pretty close to my experience with a 5 x 12 x 30 plate hx; assumed 5 gpm both sides):
Boiler......................System
138,000 btu/hr.......100,000 btu/hr..........72% efficiency
In / 185..................In / 130
Out / 130...............Out / 170
or
62625 btu/hr...........37575 btu/hr.............60% efficiency
Side 1 Temps...........Side 2 Temps
In / 185...................In / 160
Out / 160................Out / 175
Other posts suggest a 70 plate likely would be better, and I agree, for a gasification boiler system, especially at the high temp, closer delta T, applications, such as baseboard and charging storage. For radiant without storage the 30 plate might be considered.
Weight; 4.21 lbs
5 gpm each side
My comments:
or
