Don’t you wish you could get back the last 2 winters? I am 100% going in a different direction next season.
Good luck, will be watching from the side lines.
I was on their web site yesterday. The OWB you are buying looks to be a gasifier ? It definitely would be nice to have all of the mess outside and not have to C/S/S so much
There is no luck with this decision. With discussions from members here and other places this is a VERY informed decision. I’m picking up a Crown Royal MP7300 on Sunday. The plan was always to install an OWB within the next 5 years. HY-C just moved up my timeline a little sooner. Not liking the amount invested in doing this, no UTV for me yet but, it will be worth it.
Seems like the best of both worlds. Do these models have a lot of smoke or is it pretty much like a normal indoor EPA Wood Stove?It’s the multi pass not a gasser.
I’m sure they are just like anything else. Burn them wrong and they will be calling the fire department for a possible structure fire. Do it right and, while not as efficient and a gasser, I’m sure it will be fairly clean.Seems like the best of both worlds. Do these models have a lot of smoke or is it pretty much like a normal indoor EPA Wood Stove?
I read on their website 99% efficiency for the gassifier version, that's nutsI’m sure they are just like anything else. Burn them wrong and they will be calling the fire department for a possible structure fire. Do it right and, while not as efficient and a gasser, I’m sure it will be fairly clean.
Agree, most gassers are under 80%. Otherwise you'd have to condense the exhaust gasses. 99% just means it burns up all the wood cleanly, 1% leaves as smoke.
Look up the list of compliant EPA hydronic heaters to get real efficiency numbers.
I spent a couple of days in a test lab a few years ago watching some testing on some non-gassers, was surprised how much efficiency varied depending on loading practises.
OP, sorry for thread jacking! How efficient were the non gassers testing? Most of my reading has been on gassifier boilers, especially the natural draft gassifier.
I have noticed some of those same things on my Heatmaster C series. If I pack it to the ceiling it smokes more and seems to take longer to recover. Leaving some room for reburn over the fire helps a lot with that and I have opened the door during a hot burn and witnessed some good blue flame secondary action happening in the baffle area on top. I think that only happens during a longer heat cycle on a properly loaded firebox though. If I fill it 1/3-1/2 full and leave some room at the front for air to get up through the grates I get hardly any smoke at all; just a heat signature. The fire is very intense, almost white flame color, at the grate level with the fan running on a proper load.
Same thing with the ash pan, I keep it clean and empty it out every couple days. It's too easy not to and makes the furnace work much better as in faster recovery and less smoke. My ash doubles as an awesome traction aid/snow melt on my driveway in winter.
Flue temps (measured 16-20" up the stack) usually settle somewhere in the 5-700 range with the multi-pass area cleaned out and I notice they climb a little when it's time to clean. I tried removing all the baffles and running it during a cleaning and saw flue temp up into the 1200-1300 range. Goes to show how well this simple multi-pass exchanger works. I think you'll be very happy with your Crown Royal stove @Medic21. They have gone a step further with the heat exchange area and sound like a great company as well. I believe they have the most efficient non-gasifier out there.
I am very happy with mine. But it's worth saying that there is still periodically smoke, just much less than some of the simpler units I've been around. As E Yoder said, loading practices are a big variable. I loaded it with too much junk and scraps the first few times and it was pumping out smoke like a train. 10 minutes after loading however, it clears up and smoke is minimal.That's quite impressive for an inherently inefficient water cooled firebox. I can see being able to fairly efficiently burn any type of biomass without smoke to be a great benefit to this style of boiler.
