I went ahead and put a telephone deposit on a BK boxer from a dealer about 2.5 hrs away today. I'm not sure when I will actually pick up the stove but it will be a while. At first I was thinking of doing a corner install on the right side of the room photo. Then I got thinking if it were possible to place the boxer in front of this window, the window is 4'x5'. The main reason would be to keep the chimney height on the outside of the house from being less high then it would be with a corner install. The rear clearance on the double walled Boxer is 10". From what I was reading windows arent considered combustable, but the trim work is. The window sits up 2' higher than the floor and the Boxers. overall height is 39" to the top of the flu ridge. With some quick measurements I gain about 1' of inside roof pitch from the corner to the center of the window. And roughly 4' more on the outside roof. The center of the window is about 8' from the corner of the wall looking right at the room photo. I added the outside photo showing the center of the window in conjunction to the roofline vs about 2-3 feet from the edge of the outside wall where a corner install would likely be. I'm open to suggestions whether or not placing the stove in front of the window is a feasible idea, thanks again guys.
![Placement question Placement question](https://www.hearth.com/talk/data/attachments/298/298098-20145a9f9a23600f1e81370e23cd9cbf.jpg)
![Placement question Placement question](https://www.hearth.com/talk/data/attachments/298/298099-70d4fc6daf06963cb549006d85a7c916.jpg)
