stevec77 said:
I have a cabin with a 20' cathedral ceiling that collects the heat my stove puts out. I want to pipe that heat to 3 back rooms ideally but would settle for one. I'm on batteries and an inverter so running a powerful fan would drain them quickly. The in-line booster fans are low wattage but too wimpy, I was told, to push air in this application.
What if I installed a cold air return duct in the back room, ran the duct under the cabin and had it come up or return to the floor behind my wood stove? Do you think that the upward movement of the air around my stove would "pull" air from the cold air return as it rose up above my stove and thus create air movement in the back room that might result in pulling some warm air into that back room? It is a crazy idea maybe but what do you folks think?
Hi Steve, and welcome! It sounds like you're living the good life, off the grid in your cabin.
Here are my thoughts--I'm not an expert on codes or HVAC, but I am a scientist and have done a little nosing around. Anyway, it happens that I made that exact suggestion in another thread, and no one had a heart attack, so that's a helpful sign. Folks have reported that moving the cool air around is the way to go, and hot air will replace it. Most do it with fans, but I have heard of more than one doing it with ducts, and being pleased.
I believe it was BattenKiller (please correct me if I'm wrong), who said he did such an arrangement for a friend, and it worked so well that the friend still gives him beers in thanks.
There are two key innovations:
1. Running a separate powered duct, independent of the central heating system.
2. Moving cold air from a distant area, and dumping it near the stove.
I'm betting the air movement by convection would be better than nothing (insulate the **** out of that duct!), and that you'll need an inline duct fan to get useful flow. But I bet that useful flow doesn't need to be very much, and that a battery could run it. Just a little movement would make a difference over time.
Regarding your cathedral ceiling, and your lack of electricity, you may have to just accept the inefficiency. You could use the same principle, and aim a floor fan upward. Actually, I believe large fans are quite efficient, and don't use a lot of power at low speeds. You could consider putting a big ceiling fan up there, and running it on low if you can spare the juice. But even a flow fan on low speed might make a big difference.
Regarding code, I believe the rule is you cannot have a *return* inlet for your central HVAC within something like 10 feet of a wood stove. I'm guessing the reason is that if the stove belches carbon monoxide, it won't get recirculated in concentrated form and kill you in your sleep. Seems like a good idea.
But I know of no such restriction for
outlets, which is what you are proposing, other than not having combustibles within the specified clearances for your stove. I'm planning on having an outlet behind my stove, for the same reason--I'm planning on locating it
behind the metal wall shield behind my stove, to cool it and augment natural convection.
And of course, you should insulate the Dickens out of your cabin and ductwork to make it work. If you're gushing heat to the outside, no low-power fixes are going to work.
The short version: I think your idea is great, and that you should go for it with an insulated and powered duct, and make sure to come back and tell us all how you made out so we can learn from you.
HTH, and good luck!
