Question for those that have done DIY work on their central heat-
I'm in a large and old farmhouse that currently has a very old Fitzgibbons 400 oil boiler and hydronic heat zoned into 2 main feed/return loops with branch lines for the cast iron radiators (comes off feed through radiator and onto the return line).
The plumbing is all 'black iron' pipe. Needless to say, I'd like to have more than 2 zones for about 3500 sq ft of floor space, plus the system I have is not well balanced. I'm sure the radiator and plumbing sizing was all done by rule of thumb. The radiator valves either leak through or don't turn at all.
I'm replacing the oil boiler this summer with a more efficient unit. Next year or the year following I plan on doing a gasifier install, followed by storage as time/budget permits.
To rezone the heat with the current plumbing would be at best extremely difficult, given how I plant to rezone.
About 1/2 of the plumbing is in a dirt crawlspace, and 1/2 in a stone basement. Is oxygen barrier pex suitable/practical/cost effective? Copper in the diameter and wall thickness I'd need (doing rough estimates of heat demand and flow requirements) would be insanely expensive, plus I'd have to use dielectric unions at every radiator... I'm not a big fan of cutting and threading steel pipe, but that might be my best choice.
Were you in my shoes, what material would you use for replacement?
