When I try to light the pilot in my LP gas log set, it seems as if there is so much pressure the pilot won't stay lit (also sounds a bit like a blowtorch). If I close the gas inlet valve approx 90%, I can get it to stay on as a small blue flame.
Here's some background ... log set was installed last winter and seemed to work fine off of a used 20lb grill tank. This year I purchased a new 30lb tank and just had it filled. Nothing else is different.
Log set was purchased many years ago (although I just got around to installing it last year). Emberglow Sure Heat CLVT24LP.
Regulator at tank is a Char-Broil 5958727 with an outlet pressure of 11" W.C.
Any ideas? Thanks in advance for your help.
