This stove came with the house and was originally used as supplementary heat in the kitchen.
We remodeled and moved it to a sunroom. During that process all wiring was removed (not by me).
It had previously been run with a wall mounted thermostat.
I had my contractor setup the gas line to it. When testing initially I couldn’t get the pilot lit.
I took it apart and found the pilot was in rough shape so I ordered and installed a new pilot assembly. I believe it contains the thermopile and thermocouple as well. It’s similar to this - https://www.fire-parts.com/collecti...ucts/sit-top-mount-pilot-assembly-natural-gas
The terminals to control the flame also were not hooked up. So I guessed at the correct order and connected the thermostat/off/on rocker control switch.
After that the pilot lights fine, stays lit for a short period, and I am able to run the stove as expected using the switch to turn it on. The problem is once I turn it off the pilot dies. Also if I light the pilot and leave it set to pilot the pilot will eventually go out. I’d say the pilot probably stays lit for about 10 minutes.
Before I troubleshoot further - I wanted to check the connections on the back. I think I may be missing a wire or two. I looked at the wiring diagram but I’m not great at reading it.
Any help is appreciated.
