Hello all,
I have had a new PE alderlea T5 installed this summer and I am now running first fires of the season to learn this new stove. One bit of frustration is that during a cold startup, a significant amount of smoke billows out from the bottom of the stove and fills our house with smoke...even with the front door completely shut! I was expecting a little smoke if the door is open but was expecting it to be sealed off if I shut the door. The smoke only backdrafts into the room until the chimney warms and a proper draft starts up.
I looked under the stove to see if I could locate where the smoke is coming from. I thought that maybe the ash dump door was blocked with a chunk of coal or something, but I made sure it was clear before starting a fire. After I lit it up, I could see that smoke was coming out of the air control intake. The air control has a triangular shaped stainless flap that covers or uncovers a large hole (see picture). The smoke comes out of this open hole. There is also a small drilled hole, maybe half inch in diameter next to the air control that some smoke also blows out of. Does anyone have any experience with this and have any advice? Any thoughts on what that small hole is next to the air control intake (see picture)?
My house is a new modern home, single story with a whole house fan. The whole house fan takes room air and blows it to the outside...it has no off switch, only high or low. For this reason the house is constantly under negative pressure and therefore I requested the installation of an outside air connection for the stove with the perhaps naïve expectation that this would separate the stove draft properties from the pressure of the house. My set up is essentially a straight shot chimney, there is a small 30 degree or so offset near the ceiling. The stove was professionally installed by the company that sells PE stoves and the installation was inspected.
The air control system is at the bottom front of the stove while the outside air comes in at the bottom back of the stove. It appears that the air control intake is not connected in any way to the outside air intake. The air control is open to draw from the room air only. I presume that once the air control lever is shut closed, the stove draws from the outside air. Not sure why it was engineered this way - what I was hoping for was outside air draft to be most beneficial on cold startup before the chimney draft is established and stove really needs to overcome the negative house pressure. I also rarely completely shut the air control lever completely shut so as to avoid smoldering the fire. Seems like my set up likes just a bit of air from the air control system.
Lastly, I was wondering if anyone could advise me on the proper installation of the outside air. My installer used flex tube and simply pushed it into a large hole on the bottom back of the stove (see pictures). Is this sufficient? It is in now way sealed from the room air and I was able to easily remove the flex tube from the hole. I was expecting there to be an air tight adapter or something, perhaps at least some furnace tape or something like that.
thanks you...all advice and discussion welcome.![*PICS* - New Pacific Energy Alderlea T5 - Smokes the room on start up with door closed + outside air question *PICS* - New Pacific Energy Alderlea T5 - Smokes the room on start up with door closed + outside air question](https://www.hearth.com/talk/data/attachments/264/264703-5687b1afa0cb57c6cea0238102c714a3.jpg)
![*PICS* - New Pacific Energy Alderlea T5 - Smokes the room on start up with door closed + outside air question *PICS* - New Pacific Energy Alderlea T5 - Smokes the room on start up with door closed + outside air question](https://www.hearth.com/talk/data/attachments/264/264704-f2fc8b60c83f969e4254f9a5fd03933a.jpg)
![*PICS* - New Pacific Energy Alderlea T5 - Smokes the room on start up with door closed + outside air question *PICS* - New Pacific Energy Alderlea T5 - Smokes the room on start up with door closed + outside air question](https://www.hearth.com/talk/data/attachments/264/264705-f364ffb231d10f246019071b91e24353.jpg)
![*PICS* - New Pacific Energy Alderlea T5 - Smokes the room on start up with door closed + outside air question *PICS* - New Pacific Energy Alderlea T5 - Smokes the room on start up with door closed + outside air question](https://www.hearth.com/talk/data/attachments/264/264706-56f77067cae0392c1ee9eee5c10eb963.jpg)
