Hi,
I'm currently getting all the pieces together for a new stove/chimney install in the house we bought last year and I just picked up 18' of stainless class A chimney pipe (6") on craigslist for $100. That's obviously a killer price so I am now considering running that stuff all the way from the stove through the ceiling and above the roof. I did a little bit of reading on these forums and learned a lot but still have a few questions.
First some background on my install: I'm installing the stove in the living room where we have vaulted ceilings (11' from floor to ceiling). We have a metal roof and I would have to run the chimney about 4' out of the roof (to meet the 2' clearance in a 10' radius code). Technically i have enough class A pipe to run the chimney all the way! The stove I bought (1982 BK Pricess PT-202) is an older pre-EPA stove with an 8" flue which I am planning on reducing to 6". The previous owner of the stove had done the same thing plus I figure that the class A pipe will keep the chimney hot and draft high, especially considering the length of the stack.
Here are my questions:
- Is it a bad idea to reduce the flue from 8" to 6" considering I run a long stack of class A straight through the ceiling/roof?
- What piece do I need to buy to reduce the flue from 8" to 6" class A chimney pipe?
- Do I need a ceiling support box or can I just run the class A through the ceiling a brace it to the ceiling rafters while maintaining the 2" clearances? I have two brackets that are meant for screwing to rafters.
Thanks everyone for your help!
Chris
Chris
