Cold test of all component
Now that the cleaning is done we can start to test the components of your stove it’s called, the cold test. You will need to enter in, the parameter menu first, let’s have a look at your control panel
Take note of the numbers 1 to 6 below the control buttons![[Hearth.com] Piazzetta A to Z part 02 cold test [Hearth.com] Piazzetta A to Z part 02 cold test](https://www.hearth.com/talk/data/attachments/163/163498-7807a28f6614e7628d956050c0753ae4.jpg?hash=Zs33HCFbmu)
It is possible to operate the electrical components individually (Igniter, Exhaust fan, Auger motor, Room fan) in order to do a diagnostic check on each component. The test may be carried out on each component separately or all at the same time.
To do so;
Press the 6 for 3 seconds
Press the 6 to scroll in menu select language, unit of measurement, set clock, set Chrono, energy saving and menu parameter.
Once at menu parameter press the 3 (set button)
Once setting factory appear press the 3 (set button) again
You will be ask for a code
Scroll up with 2, and down with 1, the code your looking for is F5 then press 3 for set
![[Hearth.com] Piazzetta A to Z part 02 cold test [Hearth.com] Piazzetta A to Z part 02 cold test](https://www.hearth.com/talk/data/attachments/163/163499-29bf85e14b3640b56a23c840190ea627.jpg?hash=InN5Mo3RVG)
Pressing individual buttons will activate the test of each of the electrical components separately or all at the same time thus allowing you to do a diagnostic check.
Pressing button #1 > CHECK AUGER MOTOR
The auger motor activates (as you should hear the motor turning) and the display shows the letter c.
NOTE: each function may be deactivated by pressing the same button a second time.
Pressing button # 2 > CHECK IGNITER
The igniter turns on (as you should hear a quick click) and the display shows the letter A.
Pressing key # 5 > CHECK ROOM FAN MOTOR
![[Hearth.com] Piazzetta A to Z part 02 cold test [Hearth.com] Piazzetta A to Z part 02 cold test](https://www.hearth.com/talk/data/attachments/163/163502-bbf48639e18b13ff91c36605def53e2c.jpg?hash=RGCC7NDczj)
The room fan turns on ( as you may feel the air editing the unit)and the displays shows the letter V.
Pressing key # 6 > CHECK EXHAUST FAN MOTOR
![[Hearth.com] Piazzetta A to Z part 02 cold test [Hearth.com] Piazzetta A to Z part 02 cold test](https://www.hearth.com/talk/data/attachments/163/163503-718ecc436e04add2686f5434a790b018.jpg?hash=35McTF4B1O)
The exhaust fan turns on ( as you will hear and feel air being force out the rear flue pipe) and the display will show the letter F.
Pressing the key # 3 > GENERAL CHECK
![[Hearth.com] Piazzetta A to Z part 02 cold test [Hearth.com] Piazzetta A to Z part 02 cold test](https://www.hearth.com/talk/data/attachments/163/163504-be64873797ef0cced0f55af21d1a05ea.jpg?hash=39EY0jLPOu)
ALL ELECTRONICAL COMPONENTS ARE ACTIVED SIMULTANEOUSELY
The display shows all the letters A V C F
By pressing key # 3 a second time the test is terminated.
This ends the cold test of your electric components
To do so;
