We installed a Piazetta Sabrina last fall. I performed the install myself, as I had previously installed a pellet stove and a few wood stoves, and everything seemed to go well at first. About a month ago, it seemed like the stove was starting to burn more pellets. When it was first installed, it would burn less than a full bag in 24 hours on the lowest setting. It started to get only about 16 hours out of a bag on low. It also had a lazy flame, but it had had that since the install. The glass also was covered in soot within 12 hrs of a clean out. I was pretty regular with the cleaning, so I was having a bit of trouble figuring out why. The burn pot was also full within 24 hours
I performed a complete clean on it (everything including the chimney), and it got a little better, but still not what I would consider good. I have a large Enviro Maxx stove out in my shop, and it has run flawlessly for years, and I get by with a cleaning at best once a week. I googled the stove name and found this site!
I would like to thank all the people that contribute to the threads on here.. It didn't take me long to figure out most of the issues. It seemed that someone at the dealership had messed up the factory settings, as the settings were all over the place. I set the fan speed a little higher and it basically cured the issues. I ordered a cheap Manometer and just finished fine tuning the stove. What an improvement
The glass stays clean, the stove burns hotter and cleaner, and it doesn't soot up as bad as it was.
I guess the only question I have is has anyone had the same issue with the stove suddenly burning more pellets? The feed rate was never altered from the date of install, and the feed rate for level 1 was one of the only settings that matched factory at 3.3. From everything I've read about the stove, this should have been impossible. I have since adjusted the feed rate down to 2.8, and it seems to be performing better, but it doesn't seem possible that it was burning that many pellets on level 1. Any answers??? Lol
![shock !!! !!!](/talk/styles/default/xenforo/smileys/shock.gif)
