This stove was never installed.
The Piazetta Monia pellet stove features forced ventilation through the standard rear outlet, or the optional left side outlet. The control panel has digital controls, that are programmable. The optional remote control is not included but may be available from some wood pellet stove dealers.
GENERAL FEATURES
•Heating: through forced ventilation, 1 fan
•Structure: in steel
•Top surface: majolica, cast iron
•Door: cast iron, 0.197" (5 mm) ceramic glass resistant to 750°C (1382 °F)
•Firebox: cast iron
•Grate: in cast iron
•Power adjustment: 4 positions
•Ash collection: extractable ash drawer
•Function control: appliance control panel
•Provided as standard: power cable (length 6' / 180 cm), room temperature probe, grate deflector, hex wrench, firedoor opening tool (separable handle)
•Programming: 6 daily time frames
TECHNICAL DETAILS
•Model MONIA 2.0
•Heat Input (Low-High burn rate) Btu/hr 12871 - 36944 •Heat Input (Low-High burn rate) kW 3.8 - 10.8
•Heat Output (Low-High burn rate) Btu/hr 10479 - 30574 •Heat Output (Low-High burn rate) kW 3.1 - 9.0
•Burn rate (wet) - Low-High burn rate kg/hr 0.71 - 2.04 •Burn rate (wet) - Low-High burn rate lb/hr 1.57 - 4.51 •Heating Efficiency (LHV basis) % 88.8
•Heating Efficiency (HHV basis) % 82.4
•Overall Particulate Emission Rate g/hr 0.820 •Dimensions (WxDxH) cm 54.3x47.9x99.1
•Dimensions (WxDxH) inch 21.3x18.8x39.0
•Weight of appliance with cladding lb (kg) 216 (98) •Approximate hopper capacity lb (kg) 35 (16)
The miscellaneous venting parts we have for this stove are also included.
Paid $4,000 asking $2,900 OBO.
GENERAL FEATURES
•Firebox: cast iron
TECHNICAL DETAILS
•Model MONIA 2.0
