Rather than hijack other threads too much I figure I should put my comments in a new discussion... Below is a summary of where I am so far taken from an answer I posted elsewhere last night -
I've been taking the seasoning process VERY slow simply out of an overabundance of caution. The first fire was just kindling and only took stovetop up to about 150* yet there was some sizzling and obvious wet areas particularly around the door so I know it did some good. Door was a bit 'stuck' when stove had cooled down but not a big deal and seems to work fine, I think some cement or some such just got stuck in there.
Second was a larger pile of kindling and a bit higher temp and I saw some wet areas in back of the stove (inside) near where the metal slanted top ends - no sizzling this time though.
Third I put a couple small splits in there as well under the kindling (doing top-down fires each time with 1/4 super cedar as starter) and actually got up to cat temp so I engaged it and I swear I saw some secondary burn in there to boot. Max temp wasn't much over 300 I don't think so it really wasn't much of a burn as it was about done with the flames when I engaged the cat. Stayed warm for quite a while.
Fourth (this one) I put in 4 splits (small/medium) as well as slightly less kindling (just enough to get it going). This time it definitely got up to cat engaged and I did see the secondaries burn for a bit. Warm outside (about 50*) so not ideal temps for draft etc - flame went out in stove when less than 1/2 on air, but would flame up when I adjusted air up. Too dark to look for smoke outside but temps on stovetop indicate it was burning the cat. After down to coals I checked surface temp and the stones were reading 300+, out of curiosity I lifted the middle stone and checked the cooktop under with the IR gun and it read something like 450-500 so clearly it was good and hot in there.
As to the smell - each burn so far has had some smell - seems to be different with each one. It has not been unbearable and we have not opened any windows as a result. Then again - I haven't cranked up the heat yet either. I suspect that I'll get smell (as usual) every time I hit a new high temp so I'm prepared for more in the next few burns.
I'm not sure if I'm going to consider myself done with seasoning or not. I didn't see any moisture during this 4th burn or hear any sizzling so perhaps it is all done now - I'll inspect the inside of the box and make a decision later. Perhaps the weather will decide for me in the end as tonight's fire was enough to take the house up 3-4 degrees and the wife thought it was a bit warm - so enough for today!
Overall I'm quite pleased really - eager to really BURN the stove to see what it can do. This morning I did another 'medium' fire - about 4 splits worth of wood including the kindling. Was easy to get going in my morning "kid prep" routine. Obviously I was watching it more than I will in the future but really nothing much to getting it going and I did engage the cat after about 30-40 minutes (?). Was burning somewhat low - flames were lazy to not there after a while. No smoke out the stack when I left and returned from dropping kids off at school. Clearly is able to put out heat - warmed the house a noticeable amount, but then again it was in the 40's outside so I don't think that is all that hard to do.
I am having to give it more air than I expected - running between 1/2 and 3/4 open. But I am attributing that to the warmer weather. If it were not for playing with a new stove I doubt I'd even be burning when it is 50* outside and I know even with the FV I had marginal draft at these temps.
