Is thie Pferd ChainSharp a good investment? I'm not an expert at sharpening and am looking for something one notch better than a simple file guide.
Thanks very much.
Thanks very much.
Bigg_Redd said:I say get one, try it for a while, and report back.
Mass. Wine Guy said:Although, I must add that I recently got a stump vice and used it this morning when I filed my chain (in a Stihl hand file guide). What a terrific little invention that vice is. It's a lot easier to file a chain when the rest of the saw isn't moving.
Mass. Wine Guy said:What are the pros and cons of a skip chain?
Bigg_Redd said:Mass. Wine Guy said:What are the pros and cons of a skip chain?
Having run full comp and skip tooth chains on my 290 I can't see/feel/notice any difference in performance between the two. The only difference I notice is that I'm filing half the teeth with a skip tooth.
Contrary to what others say, it's not so much about the horsepower. Doesn't really matter how many horses you have if you run out of space for the chips.Mass. Wine Guy said:What are the pros and cons of a skip chain?
LLigetfa said:Contrary to what others say, it's not so much about the horsepower. Doesn't really matter how many horses you have if you run out of space for the chips.Mass. Wine Guy said:What are the pros and cons of a skip chain?
With a long bar in big wood, a single cutter builds up a lot of chips that need to be carried the length of the cut. There is only so much space between the cutters for all those chips before it packs and lifts the cutters up out of contact with the wood. Fewer cutters means fewer chips per cutter and more space between cutters for chips.
Ja, same thing, only different.Battenkiller said:LLigetfa said:Contrary to what others say, it's not so much about the horsepower. Doesn't really matter how many horses you have if you run out of space for the chips.Mass. Wine Guy said:What are the pros and cons of a skip chain?
I don't know much about chain design, but what you are saying is certainly true for band saws. The deeper the cut (the thicker the wood), the less teeth per inch and the deeper the gullets (necessitating a wider blade) need to be. Packed chips in the gullets leads to heat buildup and metal fatigue, besides the obvious poor cutting that occurs.
This is true no matter how big or small the motor is on the band saw, so I think what you are saying about horsepower in a chainsaw is correct as well. In fact, some guys get bigger and more powerful band saws and make even worse cuts with the same improper blades because they end up being able to push the wood harder into the blade teeth without stalling the motor. This just bows the blade in the kerf in a way you can't see until the cut is finished. With a band saw, you can compensate for this a bit by using less pressure (slower feed rate), but with a chain you have the weight of the saw and the height of the raker teeth that dictate feed rate and cutting depth, as least that's the way I understand it.
BTW, skip tooth designs are also the preferred tooth configuration for re-sawing thick wood on a band saw. They look like they'd make a rougher cut, but since they cut so efficiently, the cut is smoother (and much faster) than with a regular tooth design.
