Hi All,
Following a lot of research and information gained mostly from this forum I installed my BioMass 60 with a 1000 gal storage tank which has been working very well for me for the last 3 winters now. The furnace and storage tank are located in an outbuilding about 100' from my 4000 sq ft home. Between the buildings I buried four 1" PEX-AL-PEX pipes (I have 2 separate zones in my home) which were well insulated by constructing a box out of rigid polyurethane insulation board (the kind designed for underground applications) and then poured 2-part pourable urethane foam around the evenly separated pipes. All of this was completely surrounded by 3-4" of 1/2" gravel to eliminate the possibility of a sharp rock puncturing a line and also to facilitate drainage of groundwater.
Aside from a few minor leaks, this setup has worked flawlessly for me for the last 3 winters...till this Fall. One evening last week I noticed I was losing heat rapidly from one of my zones. I was able to determine which pipe was leaking and shut it down, continuing to heat my home with the remaining zone. Since I knew which pipe had failed and hence the location of the pipe in the insulated box, I started digging on the appropriate side of the lines with my tractor and front-end loader till I found the failure.
As you can see from the attached photos, the failure is a lateral split approx. 10" long along the side of the tube. My question to anyone that can answer is how could this have possibly happened? I went the PEX-AL-PEX route because of the extremely low failure rate of this stuff (I purchased the tubing from Cozy Heat). The highest water temperature to ever go through this is 185 deg F, pressure never over 20 psi.
My next question is how do I best make the repair on this? I suppose a couple of compression couplings http://cozyheat.3dcartstores.com/Compression-Coupling_p_427.html with a piece of scrap tubing between them would maybe work, but surely someone makes a repair coupling designed for an onsite repair.
Any help would be appreciated.
David
http://s826.photobucket.com/user/Shelterman33/media/2013-10-27_19-11-15_614.jpg.html
http://s826.photobucket.com/user/Shelterman33/media/2013-10-27_17-52-57_857.jpg.html
http://s826.photobucket.com/user/Shelterman33/media/2013-10-27_18-05-12_669.jpg.html
http://s826.photobucket.com/user/Shelterman33/media/2013-10-27_18-15-08_945.jpg.html
David
![PEX-AL-PEX Tubing Failure PEX-AL-PEX Tubing Failure](/talk/proxy.php?image=http%3A%2F%2Fs826.photobucket.com%2Fuser%2FShelterman33%2Fmedia%2F2013-10-27_19-11-15_614.jpg.html&hash=eb059495291682d0a752951be6443c66)
![PEX-AL-PEX Tubing Failure PEX-AL-PEX Tubing Failure](/talk/proxy.php?image=http%3A%2F%2Fs826.photobucket.com%2Fuser%2FShelterman33%2Fmedia%2F2013-10-27_17-52-57_857.jpg.html&hash=be282f8e8abd34ad0a91b6db320709c5)
![PEX-AL-PEX Tubing Failure PEX-AL-PEX Tubing Failure](/talk/proxy.php?image=http%3A%2F%2Fs826.photobucket.com%2Fuser%2FShelterman33%2Fmedia%2F2013-10-27_18-05-12_669.jpg.html&hash=638292bdecfd82c05689f8e6c1fb1dc3)
![PEX-AL-PEX Tubing Failure PEX-AL-PEX Tubing Failure](/talk/proxy.php?image=http%3A%2F%2Fs826.photobucket.com%2Fuser%2FShelterman33%2Fmedia%2F2013-10-27_18-15-08_945.jpg.html&hash=aa04f3342ed8de1f601f5db7ea76bd05)
