A year ago I posted about my thoughts on upgrading my Shenandoah 1970s stove
www.hearth.com
and got good feedback. I added 4 feet of insulated chimney above my masonry chimney and then last week of February 2021 picked up a Summers Heat 2,000 sq ft stove from Lowes for $375. Figured for that price I'd try it out and if I don't like it, will go for something higher end.
So far, I mostly like the new stove, but I'm experiencing what many others have found with the Madison stoves -- with more than just a few pieces of wood it runs away in temperature. I've scoured hearth.com for all of the threads spanning the last decade about the Madison and high temps. I've done the dollar bill test on the stove, checked the glass placement, and everything seems good. I've used bigger splits of wood.
Following advice in earlier threads, I thought I was improving by pulling out (closing) the stove air intake earlier to control the burn. But 2 nights ago, once again, I had a medium load going, air was shut down to the point that there wasn't a ton of flame activity in the box. I kept an eye on it, because I feared I might have closed down too early and it would start smoking. Instead, 15 or 20 minutes passed and I guess as the wood off-gassed the box was full of flames, secondaries roaring as well. Stovetop thermometer placed in center in front of flue rose to 700+ and the thermometer on the single wall flue was in the high 500s. With my IR gun, if I scanned the stovetop above where the secondaries were brightest, I was in the mid to even upper 700s range.
I flipped on the blower on the back of the stove and placed a small tabletop fan on a nearby counter blowing across the top of the stove. After 30 minutes or so everything calmed down.
I know this Madison topic has been seemingly beaten to death on the forums over the years, so I'm not looking for people to repeat the advice given before. Rather, in previous threads some contributors have suggested that temps in the 700s or even 800 for a bit shouldn't be worried about. Others have suggested that blocking air into the air intake at the bottom of the pedestal could help (while being mindful not to suffocate it and build up volatile gases). So I'm wondering what the outcome has been for any other users of the Madison experiencing high temps? Have any of you run it at these higher temps often for multiple seasons? Anyone experienced damage to their Madison stove caused by prolonged high temps? Any additional input would be appreciated!
Upgrade to Summers Heat -- Looking for input!
Looking for input on a stove upgrade. I live in a 1930s 1,050 square foot log cabin in northern New England. Place came with a 1970s-era Shenandoah R-77 bimetal woodstove--definitely an inefficient stove but at least a beast that can heat during single digit and sub-zero cold. After a few...
![www.hearth.com](https://www.hearth.com/talk/styles/hearth/hearth/hearth-logo.png)
