Hi Everyone, I have an old Penn Royal slammer unit in my house. It has been in my family for decades and still works perfect. I will be moving to another home that was built in 1951 that has an existing original masonry fireplace (no insert) with the old trap door on the bottom for the clean out. I would like to take this Penn Royal insert with me. It’s a steel beast that throws great heat and it’s also sentimental to me. Right now the insert is only in the fireplace opening venting right up the chimney with no liner or connections. What would I need to connect this with a liner? The opening on top of my insert measures 2 7/8” x 9 3/4” and is flat with no flange. So it’s flush. I should have 5” clearance from the top of the insert to the masonry brick and more as you go further deeper in. Thank you in advance for your time!
