PelPro Symtom using the the Acrutron II or III control board:
Press start > all systems go > auger turns, igniter is lit, fan is running, 1 minute 45 seconds into lift off the stove shuts off and auger light flashes. NOT AN AUGER PROBLEM!
There are 3 trim control knobs under the control board. FAN TRIM CANNOT BE SET LOWER THAN 11' O'CLOCK POSITION! It says it in the manual. This is why. Turn the fan trim back to 12 O'Clock or past 12 and the stove will run again.
