Hello
Well, the Pelpro Bay View is running on manual now. However when stop is pressed the red heat setting light goes out, the auger stops and the green fan lights flash in sequence as the shut dwon process begins. Then the green lights go out but both the exhaust blower and convection blower still run even after the stove cools.
The Low Limit switch L120 "Open on Rise" was replaced and the Fan F140 switch "Close on Rise" was replaced.
The control panel seems suspect here. Anyone have a similar problem??
See pics below.
See pics below.
