![shock !!! !!!](/talk/styles/default/xenforo/smileys/shock.gif)
Don't look like it does in the videoDoes it have a quad style pot,igniter,thermocouple,spring type auger etc
The pp120 and this stove completely different , yours was made prior to the HHT acquisitionI own a pp120 pretty similar to yours also no ash pan
You gotta keep the burn pot clean if you want it to run efficient. It will eventually catch up on you if you let it go to far.
I basically clean my burn pot daily, and do a quick vac out of stove nothing major, bout every 3-5 days I remove the panels and dig deeper.
Do you own a leaf blower and how high up is your clean out tee from the ground?
Generally with mine I just hook up the leaf blower and it pretty much cleans the fan no removal necessary from stove, just make sure you remove the airline from vacuum switch
I'm going on about 3 years now owning it and I've had to replace the convection fan and snap disc once, and I just ordered a new door rope which in reality I'm happy so far minus the upkeep on keeping it clean
Fairly simple and easy access after you remove side panrlHow difficult is it to clean combustion motors?
Sent from my VS986 using Tapatalk
View attachment 192743 just installed one, $1299.00 at Tractor Supply, 90lb hopper, 50k BTU...$1299.00This stove is silent, looks awesome, holds more than two bags.....omg has to be the best value out there in a cast stove.
