PelPro 130 install?
Bucket
1
MA
Hi all,
I'm replacing my Ashley with a Pelpro and had a couple of questions. The exhaust and intake are on opposite sides and the exhaust exits a bit higher than the Ashley. Should I try and make the installed vent pipe work or just replace it all? Currently, it runs up the interior wall and exits at about 6-7 feet, I was thinking I'd prefer it to go straight out the wall and rise on the exterior of the building but I am having trouble finding a kit like that. I'd like to be taller than the roof line. What do you guys think?
[Hearth.com] PelPro 130 install?
I know I need a pad, it's currently sitting on a dolly so I can move things around.
You should be able to get an adjustable section of pipe(looks like duravent) and the air intake should be able to snake around without issue…also with your current install you are capturing more heat this way
Reactions: ARC and johneh
