pelletvent pro elbow
grh372
32
western mass
I recently changed pellet stoves and went to a harmon p68 from an englander. The Harmon sits lower and right now i have it set on blocks so the exhaust can line up to the harmon. Would it be bad to use an elbow pipe on the rear of the stove so i can set it on the hearth directly then the exhaust will line up to use the current
setup installed through the wall? currently it exits the stove to a cleanout "t" then straight up about 4 feet the elbow through the wall to outside.
Hello
I have had the same issue on 2 stoves that were upgraded to Harmans. I used 2 90 degree elbows to adjust to the height Harman stove flange with no issues.
