Hi, lots of good info on here, but i haven't found the answer yet i was looking for.
We have an existing fireplace install, our chimney is not brick, it's rigid pipe which i assume is insulated since it's a wood burning fire place, believe it is 9" diameter.
I see most people are running 4" flexible stainless inside of brick chimneys etc. Can i not just hook up the pellet stove to the existing pipe, essentially adapting from the 4" to the 9" or do i need to run a 4" all the way for some sort of pressure reason?
Just trying to figure out if i really need to spend $800 or so on the 4" piping when i have a an existing chimney pipe that is rated higher technically.
As for the install, i'm gutting the fireplace unit and will be create a new cavity with cementboard/tile for the pellet insert to install into so that I can get the unit flush with our hearth, instead of being up 6".
Picure attached of existing fireplace we are removing to put the pellet stove (probably an enviro m55c).
![[Hearth.com] Pellet Stove Venting - existing fireplace non-brick [Hearth.com] Pellet Stove Venting - existing fireplace non-brick](https://www.hearth.com/talk/data/attachments/317/317992-9e54a8416ff191f6f23aa722c9f1365c.jpg?hash=mVL0HXLsIW)
	![[Hearth.com] Pellet Stove Venting - existing fireplace non-brick [Hearth.com] Pellet Stove Venting - existing fireplace non-brick](https://www.hearth.com/talk/data/attachments/319/319814-e43324492ef3faf7c2d2877ae6c236c7.jpg?hash=jfIImOeGKJ)
![[Hearth.com] Pellet Stove Venting - existing fireplace non-brick [Hearth.com] Pellet Stove Venting - existing fireplace non-brick](https://www.hearth.com/talk/data/attachments/319/319815-4d9393dcb082ba369107503805785836.jpg?hash=O0BhGJtqKX)
![[Hearth.com] Pellet Stove Venting - existing fireplace non-brick [Hearth.com] Pellet Stove Venting - existing fireplace non-brick](https://www.hearth.com/talk/data/attachments/319/319816-55e0d6b521715b11eb82b1a4f33127e4.jpg?hash=uwpjGzsRpU)
![[Hearth.com] Pellet Stove Venting - existing fireplace non-brick [Hearth.com] Pellet Stove Venting - existing fireplace non-brick](https://www.hearth.com/talk/data/attachments/319/319817-be09e8b00abea8cc11315907b24cc0d9.jpg?hash=s4Y8nf2ejT)
