I have a quadrafire trekker stove installed in my basement currently. Was installed to replace the quadrafire mt vernon e2 stove(brand new) that was just put in back in Oct 2019. After many weeks of issues with the e2 and smoke filling the room among many other failed solutions to problems the dealer finally decided to yank that stove and replace with the current trekker model. I have used this stove since December with no issues other than a loud vibration that i was told would disappear after some time of use. The vibration occurs after ignition and during the first few minutes of the stove heating up to output heat into room. They installed an outside air kit for the first stove that didnt fix its problem and they left it unhooked on this trekker because they said i didnt need it. The installer told me that the OAK was probably what was causing the noise because of the cold air circulation. So this kit has been unhooked all winter... i decided to hook it up after i read an interesting article on the benefits of the air kit. The noise hasnt changed with or without the use of the OAK. The reason i myself opted to hook it up was because the glass on the stove door got really black sooted after a week and i got tired of cleaning the glass and changing trim setting to fix the problem. Nothings works
It still get black soot baked on glass and the rumble is still there. Factory setting on the trekker is 5 for feed/air. It is all incorporated into bluetooth thermostat controller with no independent settings anymore. Normally i burn Lignetic pellets because they burn very well in my mt vernon AE insert that is upstairs but didnt seem to preform quite as well in the trekker so i switch the Appalachian pellets for the trekker. Very clean pellet but still cant keep the glass from sooting even with AOK hooked up. The venting is a horizontal run off back of stove for about 1 foot then up vertical for 3 to 3 1/2 feet then a 90 to go outside thru wall to a 4 feet horizontal run that terminates outside block wall with a bullet duravent cap that is angled slightly downward to not collect rain water. Any thoughts or suggestions would be much appreciated??? Thanks so much and sorry for the long post....
![shock !!! !!!](/talk/styles/default/xenforo/smileys/shock.gif)
