Morning everyone.  Got a question.   I'm venting my pellet stove piping 3" through an existing  window in my basement.  All piping is double wall insulated and the wall thimble I'm using is a class b 3" I had from a previous project.  Iv attached a picture of the current setup.  I removed the glass and sandwiched the thimble with 2 pieces  of plywood.   Should I use an actual  thimble for pellet stoves or will this class b be ok?  Also  with the plywood being used should I change it to drywall as a non combustible? If so any suggestions  for the outside material as it would be exposed to the winter snow etc. Highest temp I saw testing was around 90 degrees after running for 30 mins.  Please don't flame me as I know this is not to code lol.  I'm basically setting this up so I can remove the piping for summer or if I move it's easily removable.
Thanks for any replies
