Hi,
I just got a pellet stove I'm trying to install and have never done this before so please go easy on me if my questions aren't the greatest.
I'm running the exhaust vent up and out of an existing chimney. The total length is somewhere around 15 to 18 feet or so.
I will be running 1 foot of double wall 3 inch pipe horizontal into the opening connecting to either a 3 inch double wall clean out connection or a 90 degree elbow...which would be better?
From there I need to run a short 3 foot long 3 inch section of pipe to get past the dogleg in the chimney...from there I am wondering if I could run another 3 or 5 foot section of 3 inch pipe into a 3 inch to 4 inch reducer and run the rest of the way up with 2 sections of 5 foot 4 inch pipe?
I am also planning on using high temp RTV at all connections and then seal that with high temp foil tape.
Thank you for any help you can provide
