We just had a Quadra Fire Mount Vernon AE pellet stove insert installed in our colonial house earlier this week. To give you an idea of the style of our house we have a living room on one end and a family room on the other. The house is about 2,100 sq, ft. The pellet insert is installed in the living room fireplace and the family room is above our garage and has a fireplace that is not currently being used. The kitchen and dining room are in the middle of the first floor. There are two entries/exits from the living room (that has the pellet insert) - one goes to the bottom of the staircase to the bedrooms and also the small front foyer and dining room and the other entry/exit goes into the kitchen and if you kept going, into the family room.
The pellet stove works wonderful with delivering heat to the living room. Of course, I'm struggling with a way to get that heat into the family room (which has one entry/exit door). I've put an oscillating fan at the living room entry/exit to the kitchen, pointing towards the family room (on a small table to bring it up higher) and that seems to help somewhat. I've done spot checks and if I have the pellet stove thermostat set at 72, I can get the living room up to that temp (obviously), the kitchen is about 67-68 and the family room is not getting above 61. I tried the fan thing to see if it will move the air around but I'm not sure that's the ultimate solution. I've also researched the small box fans that are for the tops of doorways and those might work for us.
I'm writing this to see if anyone else has this type of stove in a colonial-style house and what they've done to help move the hot air from one end of the house to the other. I'm sure I'm leaving out some detail that may help you help us *L*, please feel free to ask away. I'm liking the pellet stove idea, just need to configure it to best work for us. The TV is in the family room and I'd like to try to get that room above 61.
Thank you.
Thank you.
