OK, I am moving my pellet stove this year. Last year I had it against an exterior wall, and vented it directly out the wall. I didn't care for that and am moving it to a more central location in the house against an interior wall. Now for the question....
I have a cement block chimney in my house (ranch home) that goes from the basement through the main floor, into the attic, and out the roof. That chimney is located about 5 feet behind where I plan to put my pellet stove. So, what I was hoping to do is vent the pellet stove straight up into the attic. Then, I wanted to angle it up and over to the cement block chimney and tap it into the chimney...
Can I do this? Does anyone see where I would run into any problems?
As long as I continue an upward angle when I go through the ceiling into the attic, I should be okay, right? Is there anything to keep in mind when tapping into the cement block chimney?
Thanks...
Thanks...
