Hi, I'm new here. My wife and I moved to Prince Edward Island several months ago. This is our first winter in a very cold climate.
I'll begin by explaining the setup in our house.
We have an oil-fired boiler which distributes hot water through heat pipes and radiates out through baseboards in our house. We have two zones in our house: one for the (finished) basement and one for the main floor. That's our main source of heat. Well, we heard horror stories from people as to how much people here spend on heating their houses with oil so we purchased a pellet stove.
Note: our hot water heater is also oil-fired. Our boiler heat system is a closed system and is separate from our water system.
My routine is/was as follows: wake up in the morning and turn on the pellet stove. Run the pellet stove all day until it's time to go to bed. Turn off the pellet stove. This whole time the thermostat has been set for the oil heat in the house. Therefore, the goal was for the oil to kick in (a little) overnight, just to distribute water/heat through the system to prevent frozen pipes.
Well, it hit -30 something last weekend and my wife and I awoke to a freezing cold house. The heat pipes in one half of the main floor had frozen. Luckily, the plumber was able to thaw them without any bursting.
The source of the problem? He and I both guessed it was due to the pellet stove throwing off the thermostat (for the oil heat). I noticed this during each day. The pellet stove would heat up the main floor and the thermostat would rise above the set temperature. For example, I would have the thermostat for the main heat source (oil) set to 68 but the pellet stove would warm up the house and the thermostat current temperature would read 72. The thermostat properly noticed it was warm enough in the house so it didn't turn the oil heat on. Anyway, this caused my heat pipes to freeze.
The reason my wife and I purchased the pellet stove was to save on oil costs and to utilize a cleaner-burning heat source. Now I'm not sure what to do. I don't want my heat pipes to freeze again. What do you all recommend?
Here are some options I'm considering:
1) The plumber suggested adding glycol to the boiler. He said this would prevent freezing and we could use our pellet stove and not worry about the fact that water wouldn't be going through the heat pipes for long periods of time. He did admit this would lower the efficiency of the boiler, though (the operating temperature).
2) We moved our furniture and TV and are now using the room that has the pellet stove in it as our living room. There are doors that we could close to try to keep the heat in and just keep the living room warmer than the rest of the house. However, there is a 2 inch or so crack at the bottom of the doors so some heat would make it into the dining room and probably into the hall where the thermostat for the oil heat is.
What would you recommend?
Is it a good idea to add glycol to a boiler? I've seen pros and cons online. A lot of people seem to recommend you don't do it.
Any thoughts would be greatly appreciated. We'd love to use as little oil as possible. Thanks!
