pellet stove auger kicks on when off
pucku11
1
southern ma
i have a vistaflame pellet stove that is connected to a thermostat .when stove is off every so often it starts up drops a few pellets then shuts off ,then i would say20 min utes later it does it again ,and just keep doing that.other than that stove runs fine.it can be dangerous if off and burn pot fills to the top and then it tries to start any suggestions would be helpful thanks
Could be a messed up setting someplace (not familiar with the model), otherwise I would think the control board is bad.
What is the make and model of the thermostat? What is the differential (swing) for the thermostat set to? If it is too narrow, the stove could be getting on/off/on calls for heat. This can happen if the thermostat is too sensitive.
