Pellet Master PM-3000 Titan snap disc style - surface or stream mount? See Wire Diagram
Don2222
9,151
Salem NH
Hello
Does anyone know the mounting of the Pellet Master Stove snap discs?
I have seen the Auger Over Heat F120 Deg F snap disc which is a surface mount. No mounting hole.
How about the F110 Deg F Exhaust Temp Sensor or the Convection Fan F100 Deg F sensor or the F170 Deg F Stove Over Heat sensor? How do they mount?
Pic 1 - Wire Diagram
Pic 2-3 — Auger Over Heat Sensor
Pic 4 - Manual cover
  • Pellet Master PM-3000 Titan snap disc style - surface or stream mount? See Wire Diagram
The half round tabs are where the screws go to hold it.
Yes and they are even with the bottom of the snap disc meaning it is a flush mount.
My question is, Do the other snap discs in the stove mount this way or do they go into a hole in an air stream mount configuration?
Well, I guess the obvious question is: Are there holes for them to mount into? (Assuming you have the stove to look at.)
